Makes sense. great info. Yes it is the one that comes with the tilly 212r. I’m not sure what you mean about timing mark? I’ve never heard that.
I’m wondering about carbs. I have a 27mm but I notice a lot of builders use 22-24mm. I have a 115 jet in mine but I can’t tell if it’s lean/rich. What variables to consider when picking carb size?
Cheers
I'm not a fan of slide carbs on these engines. I perfer bored stock appearing carbs, so I can run the stock air box and filter.
Bored SA carbs can turn 8500 rpm with the right combo of parts, so there's really no need for myself to use the slide carbs.
Smaller carbs will accelerate faster for a neighborhood cruiser, daily driver, hill climbing, mud hole stomping, type builds.
Now for full blown drag racing types, yes the bigger the better, but don't expect it to be a very good on/off throttle, fast acceleration carb.
I'm sure some of the slide carb guys can help you with tuning your carb, and answer your questions.
As for as the timing marks, arc and pvl flywheels have a mark built into them, making it easier to set and adjust the ignition timing.
That 212r flywheel does not have a mark. You can find it with a piston stop, then use a degree wheel, pointer, and dial indicator to set the ignition timing.
The keyway on the crankshafts are never cut the same. This makes no 2 engines have the same timing.
I've found them to be 18-27 degrees BTDC right outta the box. Most are close to that 24 stock mark, but some are just too far away. This makes it hard to dial in a good tune when people start upgrading parts looking for more power.
Too little or too much ignition timing, will seem like all the upgrades have done absolutely nothing for performance.
This is the main reason I don't use flywheel keys and set timing myself.
That 212r flywheel has 4 degrees retard built in it.
So let's say your crank is at 20, take away 4 for flywheel, add the 7 from your filed down key and you end up 23 degrees BTDC.
That's 1 less then a low CR bone stock engine should come with.
Let's say your crank is at 26, take away 4 from flywheel, add the 7 from key, now you have 29. This is much better for a slightly modified engine like yours.
That 6 degree difference is huge when it comes to CR bump, cam timing (valve events), more air/fuel mixture.
You need to know where you are at, so you will know which direction you need to go.
Also, stock coils start retarding ignition timing around 5k rpm. As much as 6-8 around 6k.
Dover power has some really good coils if you need to run over 5k rpm and still make power.
www.doverpoweronlinestore.com
