87srvsnow
What are the best and cheapest ways to get more performance out of my 6.0 hp Tecumseh engine? I have already taken of the governor.
carb sounds expensive. where would i find a header? just some racing online store?
I bought a Mikuni 22VM for 26 dollars. Only missing one part. Also the header you could easier make one. Just get some pipe and bend on a vice. Then cover the hole thing in header wrap so then no one sees the scars from the vice.
I "found" a shopping kart and cut some pieces off that had 90degrees.
This took about 5 minutes. I reused the flange off the stock muffler.
A better carb will flow more gas, however it wont always help all that much with a stock engine, because there a limit to how much gas can flow with a stock cam, piston, etc. Im not saying it wont help a stock engine though, because it will. The only other thing to consider with a carb upgrade is that you most likely wont be able to hook up the governor to aftermarket carb.
Same with the exhaust, you want the exhaust gasses to exit as fast as possible (with a 4 stroke, 2 strokes are different), so a straight pipe will let them leave much faster, and make the piston work less pushing out the gasses.
Your not being a pain at all, the only way to learn is to ask questions.
