x-Speedy-212-x
●▬▬▬▬▬๑&
I've got plenty of things on my To Do list to keep me busy for next year and this year for the body build.
This year... Engine Build. Along with minor chassis mods. :
There are a lot of things i must do first. And some of those Must Do items are already taken care of and hidden. So no need to bring them up. Please.
Next year:
(DriveTrain)
-(this one may happen this year): Draw-Through setup OR a tuned dual carb setup. One for easy ignition and one for the powerband.
* Limited Slip differential ?
* V-TWIN 724cc engine?
____________________
*contemplating my own supercharger ideas. Dual supercharger?? It is[I/] a V-TWIN.
(Body)
*Widen?
*Seat. (after widening)
*Modified for Limited slip Transmission.
*Head Lights.
*Cage. (design in construction)
**custom Fiber-Glass body kit. (after the cage & chassis gets built).
*Downforce (design/s in construction)
*Side vents for engine cooling.
Tires:
*Taller and wider.
(Suspension)
**Needs to be lifted away from the ground. (and for the Tires and Transmission. )
* Chain tensioner needed for my concept design therefore will most likely do the basic buggy design if done.
and a ton of other stuff I would love to get accomplished.
After all that being said.. I think I still qualify for the 2017 build-off
My only limited sources are money and energy. And the proper climate temperature.
Next year:
(DriveTrain)
(Body)
*Widen?
*Head Lights.
Tires:
*Taller and wider.
(Suspension)
