performance for bigger engine
Rotore
Teh SPIK
Caguas, Puerto Rico
how many rpms could my engine handle its a 25hp Kohler commando, 725cc, twin cyl, OHV, w/ pressure lub.
here are some piks:
freakboy
the names 'mater
hick town
5000 at most i dont bring my twin anyhigher then that. but with that engine it gets a but load of torqe so you can gear ur kart really high so you get a good bit of speed and about the same exccel as you would with a smalller engine geared lower.
NJOHC
NJ
A lot of it depends on how heavy your kart is. Id gear it 5:1 and rev it to 4000RPM. But thats just me lol
Rotore
Teh SPIK
Caguas, Puerto Rico
my kart is about 230lbs with the engine and im 220lbs so it'll be 450lbs w/ me on it.
im going the probably use 18 or 20 inch wheels so 5:1 or 6:1 should get it moving right?
NJOHC
NJ
With that kind of power Id go 5:1. With that you'll have good acceleration and top speed. And if you dont like the acceleration you get you can always play around with what you like between 5:1 and 6:1. Im going to gear mine 6:1 and I only have a 9hp motor. It also depends on where you ride. I go through a lot of deep sand and I prefer really quick acceleration over top end. But I think youll be really satisfied with 5:1 with an engine like that. Good luck! I hope ya post up some vids of it, Im interested to see how it turns out!
Rotore
Teh SPIK
Caguas, Puerto Rico
awsome dude will do.
1992suburban
I wanna go FAST!!
Sanford, NC
use that calc tool me and Anderkart like so much.. if you use a tq convertor and jackshaft your options are endless..
I wouldnt turn it much maybe 5k and use gearing to make up the diff
