Peerless 700 Centrifugal Clutch
jwc4806
Do yall think a dual belt centrifugal clutch will hold up on a 16hp engine with a peerless 700 transmission. I got 19" tires and a top speed will not be more than 25mph.
anickode
S.E. Michigan
Most likely, as long as the clutch is rated for the engine HP. Being a (presumably) vertical installation, belts are definitely your best bet. Try to get a matched pair of belts. You might be able to run a 2 groove power band (banded belts) and on there instead, for increased strength, a perfect belt match, and vastly improved resistance to throwing or rolling a belt.
Kaptain Krunch
Pro Junk Collector
vermont
A clutch rated for 16hp is going to be expensive, have you considered a belt tensioner style clutch commonly found on lawn tractors?
