Pathwinder throttle rod
Aaron371
Maple Park IL
Would anyone have a picture of how the throttle rod and cable are hooked up at the rear of the Pathwinder kart? Here is what mine currently looks like. Thank you in advance!
NECRO-POST! 🪦 thread is from 2020 but never answered. Must've been due to covid or something....
Interesting question about a fairly obscure fun kart. For all people and not just the OP, this video explains the throttle setup. See @36:27 timestamp:
However, don't do like he did. The factory bracket is fine, no need to weld on an extra angle bracket. No slot is needed either, when you can draw the cable from the cable sheath, install the threaded end of the sheath in the bracket using the two nuts and then reinsert the cable.
Doodled screen shot from the video: I would flip the factory throttle rod over so the "flag" (in yellow) is on the other side. Attach the eyelet to the vertical nut and bolt on the flag, run the threaded throttle cable sheath (light blue and black) as depicted with nuts on either side of the bracket, and attach the red spring as depicted.
Edit: I goofed. The red spring should be attached straight back to the hole that bolt is in. The kart in the video had a bolt, nut and a cable clamp there but there's no need for it.
