That's not actually a problem.
You'll find a stamp telling you what plastic it is,
like you find on plastic bottles, plastic bags and any plastic part around your house.
(recycle centers NEED those stamps to sort)
you can use that same stamp to repair.
As you can see in the video he's salvaging a spray bottle as a filler material.
Personally.. I doubt it's an ABS bottle (he said so though) most bottles are PE, at least around here.
And PE and ABS do not bond too well,
the perfect bond is achieved using the same material (minor mix differences are not important)
and in the end, technically the part itself is 'as new' maybe not cosmetically,
but done right, the inner material bond of the repair is identical to the inner material bond of the uncracked part.
While fiberglass is a great material (also for repairs) it can't do that.
Don't get me wrong, whatever you feel confident and comfortable might be the choice to pick (as long as it's not utterly stupid of course)
but really.. plastic welding is as easy as using a glue gun to write a letter
clean the parts (alcohol works fine) apply heat and where necessary filling material, maybe cut off excess... done, rest is cosmetics.
PS search yt for more videos if you want, some use heat guns, some special welders...
some a propane powered pocked soldering iron...
as long as it's hot it'll work
