EpsilonZero
...still cheaper than a boat!
- Messages
- 399
- Reaction score
- 202
Or how about this one? It is over five minutes long.
I made three types of front fenders and have come to the conclusion that, unless I basically full enclose the tires, debris ends up hitting me in the face more often rather than less with the fenders on. It seems ridiculous; pebbles will hit the fender and slow down, but bounce in front of the kart and then into the kart while airborne. With no fenders at least they mostly follow a trajectory in line with the wheel. I had the best luck with flaps, but I made them for narrower tires and modified the hardware for the fenders... so now the tires just go naked!Gotta say I like the feel of acceleration over the giggle factor of tire spin.
And I realize that sticky rear tires require soft front tires to maintain steering,
which causes a debris issue. Maybe fitting (removable) front fenders when the
soft front tires are on might be a solution.
14:44What's your gearing?
If I'm doing my math right with your 11 inch tires that's good for 60 mph. So did you set an RPM limit or do run it to 60 mph?14:44
The OD on the tires is 10.5. I set the limit at 6000 or 6500, but I haven't taken it to my preferred road for speed testing yet to see if it will go any faster. It does spin up to 6000 rpm with the wheels in the air with a 6000 rpm limit (from initial tests). If it can spin at least 6000rpm under load, that would be 60mph, but I'm not holding my breath. I'll take it out for more testing as soon as I get a chance.If I'm doing my math right with your 11 inch tires that's good for 60 mph. So did you set an RPM limit or do run it to 60 mph?
I was able to hit 68+with my ME1717, but it was at the limits of what its power could deliver and acceleration was bad. I have no doubt the latest configuration could easily pass 70 with a gearing change.My original Manco kart ran a 20/53 and had decent acceleration with only a 64v pack. I bet both of our karts could hit 70 mph+ with that gearing ratio.
I tacked the hanger in without clamping and verified the axle slid freely through the bearings before fully welding.One thing to think about wrt bearings and having more than 2 axially along a shaft. Unless they are perfectly aligned, there will always be a slight bind on one of the bearings, which could cause premature wear on the bearing races/rollers. When you have two, even with a misalignment, it's usually within the tolerance of the bearing.
Looks like it launches hardA new test run with different gearing. I discovered Kelly finally added field weakening to this series of controllers, so I ordered one and the next video should feature a test run with it.
I swapped out the controller for one with field weakening (FW) and ran it with maximum FW and a cutoff at 5500rpm. FW will allow greater torque output after peak torque than normal at the expense of additional current (and heat). It can also allow the motor to spin to a higher max RPM.Lookin' good!
Could ya give us some commentary
...& tell us what is going on here
Like what is different than, your previous set up
...& why![]()
(I just threw that one in)
