outboard powerhead?????
mister twister
TOWER OF POWER is my name
minnesota.
i am in possesion of a liquid cooled straight six two stroke outboard motor that may need alot of new parts but the powerhead is ok.
so the implication is to put a sled clutch on ti and make an expansion chamber exhaust to supply the required back pressure and run it horizontally. any ideas guys? its 100 horse power if anyone is interested.
sideways
Unfinished projects king.
Perth, Western Australia
I've looked into this quite a bit as I'm putting a 50hp Mercury outboard into a car.
Contrary to popular opinion, outboards actually have a thermostat and run at quite normal temperatures. The problem is modifying them to be able to be hooked up to a radiator.
Don't worry about the exhaust, 2 strokes don't need back pressure any more than 4 strokes. (In this case anyway, at the pointy end of expansion chamber design it is useful but only to make the expansion chamber work better) You'l probably have to re make the "manifold" so that you can hook the radiator up though.
Fitting a clutch..... They mostly seem to have a splined output (I've seen old, smaller ones with a key way) so it's up to your resources and engineering prowess to figure out how you're going to fit that. If you're lucky enough, you might find a sled clutch with the same spline. Seeing as I will be fitting a car flywheel to mine, I can't offer much in the way of relevant examples.
You'l also have to sort out a water pump, rework the inlet manifold so the carbs are in a suitable position, wire the engine in and figure out a way to mount the bloody thing.
Thanks
Hayden
Sideways, at what point in time did thermostats pretty much become standard equipment in outboards? I ask because I had a '76 Evinrude 50 that was overheating, and driving me crazy. I could not find any hint of a 'stat on it, and several guys I spoke to who (should) know, said it may not even have one. I ended up selling the boat before I found out.
Start a thread somewhere! I want to see this car!!!
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
This sounds like a lot of trouble, but 100 Horsepower in a 2 stroke is a lot. If you have something planned for it, I'd like to see.
Now.. I know nothing of marine engines, but I don't see why it would be too hard to make an inlet and outlet in which water flows in/out of the engine while being pumped to some sort of radiator. As far as a cooling fan, I don;t have any ideas there. But some pictures would definitely be a plus.
mister twister
minnesota.
pics were requested, and i deliver. this engine im looking at has weak compression and i may have to hone the cylinders and buy new rings.....they are 5.00 a piece!
exenos
Project Nut
Interesting looking engine. I wonder how bad the crank whip is. Have you figured out how your going to mount it if you use it? From the looks of it one end will be easy but I'm not sure how you would secure the other end. Last question :) what is the displacement? CI or CC is fine.
