ordered a 14cc head ;)
justinkk2005
Current mods:
flat top piston
billet rod
18 lbs springs
mikuni 22 mm carb
the 14cc head make a big difference on the gx200? I'll have to run 93 wont i
comp ratio with flat top is like 11:8:1
oscaryu1
4cycle said that... lol... and seeing as they weld up/mill their own heads, and the actually port the combustion chamber... I'm inclined to think they know what they're doing...
Actually I think they might've flow bench'd it... me no remember:(
honda02
most of the guys at 4 cycle actually weld up the 18cc heads, achieve similar combustion, and still have the needed port velocity. its not really a trade off this way, but. You're 14cc head will make a diff in power and sound. My engine is 13.5:1 comp and needs 110. it sounds like a popcorn machine.
1992suburban
I wanna go FAST!!
Sanford, NC
I think youwill see no difference between shaved 18cc and a 14cc (stock) on your cart
the stock carb flows less then both heads anyways
14cc add larger stainless intake valves and unshroud them you will have a NICE head for a BAD@SS motor.. your mikuni should do fine on both.
