oops it fell out. help with cam
jj2975
i just opened up my new gx200 to remove governor gear. i tipped it up to work on and the cam fell out. do i just realign the dots and im good? this might be a dumb question but is there a procedure for this. do i just go tdc and then align dots.
kibble
I banned myself
If you could had/found a manual for it, it may tell you what to do. Most of the time it is just lining up the dots with something else in there. You could try lining up the dots and then manually rotating the crankshaft to see that it works properly and has compression and everything. If it turns too easily and has no compression then the timing could be off.
RobertD
Administrator
Texas
you want to line up the dots, and you also want to make sure it's on the right stroke, compression or exhaust. I can't remember if you engine hits them both on one "go round" of the cam or not. If they line up twice, you need to make sure you're on the right stroke.
Russ2251
AZUSA:Powered by LAWN-BOY
Marks can only line up one way. For every complete revolution of crankshaft, cam shaft will always rotate 1/2 revolution. Conversely, for every complete revolution of camshaft, crankshaft will always make exactly 2 revolutions. This never changes once set and can only be set one way. There is nothing else to check. When marks are aligned you can close it up.
kibble
I banned myself
Re-re-re-Rescue Russ
Camshaft Ranger
When there's danger!
:D
kibble
I banned myself
Ha ha! I was actually thinking of getting the Rescue Rangers logo and taking the thunder bolt out of the middle and replacing it with a cam. I didn't go that far though. LOL
