One bad egg can spoil the whole pack
If ya ever get in your electric powered go kart
...& it just doesn't seem as spunky as usual
...or worse (don't want ta go at all)
A "cell" may have gone bad in your battery pack
Here is an example of this, that I encountered this weekend
I got my Aerial Atom kart out on Saturday afternoon ta dust off the cob webs & take 'er for a spin :auto:
...but, she didn't wanna go
The 60V batt pack showed ~59V on the energy meter (fully charged should be ~65V)
...but, when I applied throttle, the voltage in the pack "sagged" all of the way down to ~51V (& it didn't wanna go) :worried2:
* I had the battery cables unhooked while it was in storage (to eliminate any "parasitic" power draws)
...connected the charger once a month (so, they don't self-discharge too much)
...& everything always seemed OK
So, I did some investigation (starting at the batt pack)
Checking with my MM (multi-meter)
...the first 12V 12AH SLA battery checked out as ~12.8V
...the second "cell" showed ~12.9V
...the third showed ~7.6V (WTF?) :furious2:
...the fourth showed ~12.8V
...& the fifth showed ~12.9V
When I removed the batteries I noticed a bit of corrosion on the batt tray
...& then, when I flipped 'er over, I noticed a crack in the bottom of battery #3 :mad2:
*Solved that mystery :thumbsup:
I connected a 12V charger & individually charged each battery
...& they all came up to ~13V (batteries #1, 2, 4 &5)
...& they were still @ ~13V the next morning (rested voltage)
** So, the moral of this story is, 1 bad egg can "spoil" the whole pack (as far as usability as a whole pack)
*** This example was about SLA (lead acid chemistry)
...but, the same principle applies to Lithium battery packs too
Like Donny Osmond almost kinda said if you twist his words. “One bad apple will spoil the whole bunch girl. “
