If i was to get these hubs=
4 x 4 Wheel Hub- 3/4" Step Down
Wheel Hub with 1" Bore and 1/4" keyway that steps down to 3/4"
1" portion of the shaft is 2-1/2" long
The 3/4" Step Down is at the Flange
(4) 1/2" bolts on a 4" bolt hole circle
And i was wondering if this would fit on this Wheel/Tire
Tire Type 2-Ply, Pneumatic
Tire Size 16 x 650 x 8
Load Capacity (lbs.)-415
Rim Size (in.)-8
Holes-4
Rim Included-Yes
Center Hole Diameter (in.)-2 3/4
Bolt Circle (in.)-4
Hub Offset (in.)-No
Tubeless Tire-Yes
Tread Type -Turf
I wanna go to live axel with some beefy tires on the back and for that price its a deal! Just wondering if the bolt paterns are the same and do you think that would be a good match or go for something diffrent. I am going to mostly riding on hard dirt and grass so i think that should do just fine. What you guys think?
Rim Size (in.)-8
Holes-4
Rim Included-Yes
Bolt Circle (in.)-4
Hub Offset (in.)-No
Tubeless Tire-Yes
Tread Type -Turf
