OMB throttle kit for removed governor?
thisismyusername
Donut Eater
Throttle for removed governor/ governor questions?
Ok so I am planning on removing my governor. I know that when you remove the governor that if you leave the linkage normal then it could move around in the engine kind of and hit moving parts, but is there a way you could stop it from moving? I thought I heard some people say they use JB weld but that it didn't work well and came off or some thing. I wan't to keep the regular throttle setup if possible. I saw the guys carsandcameras on youtube just leave theres, and they didn't jb weld it down or anything and it seems to be fine.. Any info would be appreciated..
SIDE NOTE: What is the best way to get that dang little c-clip off thats holding the governor gear on?!?!
Jrgunn5150
Rudderless
Ok, on mine, I completely removed everything.
The little C-Clip require force, and bending, and more force. No finesse was used there. From there, I rotated the piston until I could pull the linkage rod down through the block.
Up top, obviously I had completely removed the governor linkage from everything. Then i just plugged the hole with silicone.
Now I had no way to connect my linkage to the carb, so I took a metal coathanger, and bent it the correct way to hook the factory throttle hand lever to the actual carb. It took two pairs of pliers, easy peasy. From there I hooked up my throttle cable and did burnouts.
Easy Peasy huh? Lol
"I had to make several iterations of my coathanger throttle linkage. Even after I had one I tested flawlessly in my dining room, somehow it changed in the driveway lol."
Kinda easy!
---------- Post added at 09:08 PM ---------- Previous post was at 09:05 PM ----------
1 time I fought the clip next time I puched out the whole shaft from behind the flywheel.
Fight the clip or remove the flywheel.
Both sucked for me, but flywheel was easier.
thisismyusername
Donut Eater
I just bent a coat hanger like you said from the throttle directly to the hand setup and it works! So it bypasses the governor perfectly, but i didn't run it. I don't want that plastic piece to shatter. I actually had another predator 212 a while back that a buddy gave me that had a broken crankshaft, (there was a chip taken out of it and a clutch could no longer fit on the shaft) and I did the procedure of take the rod, cutting it and taking it out. Then i actually just hammered the crap out of the c- clip and the plastic part, and the plastic ended up breaking into lots of tiny pieces, but I got the c-clip and all off. But now I have a bunch of plastic pieces in the case that will be a pain to get out and ill never know if i got them all. So when i take the gear out of my engine that i'm going to use, I wan't do it right. Whats the easiest way to do it without destroying the plastic gear? All the videos on youtube just say bend it till it comes off, then they skip to where they have it bent. I couldn't seem to get it bent without destroying the gear ;D
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
If you have the side cover off, You should be able to get all the plastic pieces out no problem.
Also Good job with the coat hangar, (Jrgunn too) I got mine on the first try as well.
Sorry Bob, LOL
thisismyusername
Donut Eater
Sorry Bob, LOL
Yea im thinking about just getting all i can out with my hands, then blowing compressed air in there. Then putting the cover back on, putting some gas inside the case, swish it around a bit then taking the cover back off and draining the gas. I have heard of people using gas inside the casing, that's perfectly fine to do right?
That should be fine.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Have you already shattered this thing into a bazillion tiny microscopic pieces. Or are you just worried you might?
Cause even if it breaks coming off, it is usually just 2 ot 3 large easy to see pieces.
thisismyusername
Donut Eater
Well i had a broken predator for parts. So I took the governor off that one for "practice" and it came off in like 3 big pieces and a bunch of very small pieces too.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Just my opinion, and carefree just try it Personality.
Dont worry about it. but...
You can turn the crank so the piston is all the way up. Wipe all the excess oil out of the crank case. Then take the gear out. If it breaks find all the pieces. Triple check you got them all and move on.
You know tons of us have removed plastic governor wheels. and I dont know of a single time when somedody missed a tiny piece of plastic and grenaded their engine.
Even if you ran it with the governor diconnected only, and the gear failed. I believe it is not the plastic that ruins the engine, when it breaks. It is probably the metal c clip and other metal parts.
Here is a how to that reminds you of all the things to be careful of. There is a little metal washer that people forget sometimes.
https://www.affordablegokarts.com/govenor-removal.php
The fact that you are very concerned about this, actually gives me piece of mind, that you will be very dilligent in getting all the pieces.
So go for it.
cavfire
auburn, georgia
You can also pop the flywheel off and tap the governor gear shaft out with a punch on the backside, then thread it to 1/4-20 and put a bolt in there with a little thread sealant. Prime time to bump the timing anyway if you're going to run without a governor.
Poboy kartman
Senior Moments Member
White Settlement Texas
While I never like to hear someone has had a misfortune of any kind....the one positive facet of a thread like this is that it's a confirmation of what we try to tell people NOT to do....(and why we aren't just spouting our OPINIONS....but what we know CAN and often DOES happen.....)
Soooo.....for all you newbies that think you can upgrade your valve springs without upgrading your rods....we await your misfortunate threads so that others may see and avoid the same....
cavfire
auburn, georgia
:thumbsup: I didn't see mention of springs, but really even at the 5,200ish rpm valve float with stock springs we're closing in on 50% more rpm than intended from the factory. Less than $200 for peace of mind from a new flywheel and rod shouldn't even be balked at.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
The real issue on this build concerning Springs and Rod. There is NO seat. and this operator is using a hand throttle!
When the rod goes and turns the crankcase to Sharpnel, the driver is in severe Danger.
Kids do not try this at home. As stated this thread has many examples of what NOT to do.
I don't want to be a Richard! but Safety First. Do what you want, but this is not an example of what to do!
