Old Kawasaki Carb Cleanout
Jcotz
...wasn't there
NY
Hi, I just recently decided to clean out the carb on my old Kawasaki FA130D 4 stroke. From all the videos I have seen on cleaning out carbs almost all of them have been for carbs with bowls, not carbs directly attached to the gas tank. So I was wondering, what would be the best way to clean out the carb? I've seen that boiling it in lemon juice works, but what parts should I boil? For How long? Also, what is the best approach to taking the carb apart?
Thanks for any help.
Jcotz
...wasn't there
NY
Sorry to be persistent, but does anybody have any ideas?
Jake.B
California-USA
i i would just boil it in lemon juice for 5-10mins then spray the parts down wiith some carb cleaner. also, dont boil rubber gaskets the diaphram or any rubber plastic material.
the best way to take it apart is to just start taking it apart. remember the positions of any idle screwss or fuel:air mixture and remember where everything goes.
kendelrk
redneck engineer
westland michigan
take the carb all the way apart, as far as you can. make sure you know where everything goes and leave all the rubber pieces to the side. now take a tall pan that your mom dont like or wont mind you messing up and put lemon juice in it, set the carb ( without the rubber) into the pot and boil for about 40 minutes,make sure to get the whole carb covered in lemon juice. after straining take the carb quickly and spray it down with carb cleaner so it dosent get all dull. now take a small piece of wire and make sure all the holes in the main jet and things like that are clean, reassemble and try again
