old engine
briggy
its leaking from the hole that the air filter is supose to be attached, bypass the choke
briggy
:furious2::furious2::furious2:oohh shoott, when i took the carb off i noticed that the throtle was mixed up and i was closing it instead of opening it:censored::censored:
briggy
the hihg speed needle valve is missing can i replace it with something else?????
modelengineer
Lord of the noise
Sydney, Australia
a replacement high speed needle would probably work ;)
Can't think of anything else you could use. It's a pretty critical part, and must be accurate in order to get proper air-fuel ratio's
