j.concepcion54321
Rebuilding KTM, Need Kart
Hey guys, a friend of mine gave me an old tiller engine. Its a 5hp briggs and stratton in pretty rough shape. I think it has some potential though. some of the problems are...
Seized Carb
No Spark
Jerry rigged spark system, ill explain further down.
the tank is all rusted and according to his dad it wasnt venting properly so i guess the tank is broken. lol
and its pretty ugly.
But it was free
so im gonna try to make it a racing engine and if it doesnt work or it all blows up in my face its ok.
Ok now to adress the issues...
...the first one is the seized carb. because the carb and tank are attached and the tank is bad aswell im planning to just throw the whole assembly out and order this. http://www.ebay.com/itm/Chinese-Car...s=63&clkid=5560928237762508978#ht_2170wt_1270 then use another tank mounted somewhere else that i already have.
the second problem is the no spark/ rigged system. I tried cleaning up the spark plug and adjusting the gap of the plug a little to see if it did any thing but no luck. Im planning on getting a new plug as soon as the weather clears up and trying again. when i say rigged system is that my guess is the plug boot went out so they cut it and went to go strip the wire and wrap it around the plug. looks like they cut it too short
so they used another wire in between as well. i mean that the original wire coming from the coil is connected to another wire, and that wire just goes to the spark plug. ***** Can someone tell me if this system will work like that? If so then ill just clean up the wires some and tape em up and leave it like that. will i have any problems by doing this?*****
last problem is the ugliness. Since im going to be taking apart the engine anyways after i know it runs to remove the governor i figured that while i had it all apart id just grind off all the grime and rust off the actual block and all the engine components that may be dirty and then hit it with some paint, let it dry, and put ut all back together. then itd be nice and pretty again.
also it didnt come with an exhaust ( i think, cant check now but i dont remember seeing one ) so im probably gonna make some sort of homemade performance pipe that is quiet but not restrictive at the same time so that it gets good performance and the neighbors and my parents dont kill me.
so what do you guys think of my plan? Good , bad, questions, concerns, etc. feel free to comment.
EDIT: i forgot to mention that theres an unknown problem. When i go to crank the engine i pull the rope and it catches and turns it over, then i go to pull it again and it doesnt catch and it continues to not catch until i spin the shaft manually and then i pull it again and itll catch. and then the same thing happens after that and so on and so forth. How can i fix this problem? I an in too deep with this engine and it is just scrap? or does it have potential to be a nice fast kart engine like im hoping.
Thanks guys for taking the time to read my post. Im done now.
Seized Carb
No Spark
But it was free
so they used another wire in between as well. i mean that the original wire coming from the coil is connected to another wire, and that wire just goes to the spark plug. ***** Can someone tell me if this system will work like that? If so then ill just clean up the wires some and tape em up and leave it like that. will i have any problems by doing this?*****last problem is the ugliness. Since im going to be taking apart the engine anyways after i know it runs to remove the governor i figured that while i had it all apart id just grind off all the grime and rust off the actual block and all the engine components that may be dirty and then hit it with some paint, let it dry, and put ut all back together. then itd be nice and pretty again.
