oil the clutch?
beansdaddy78
JR. Member
Carbondale IL.
Hey I noticed somewhere your supposed to oil these clutches. What should I use to oil it? Would they sell the product at a local auto or farm tractor store? I seen on youtube that someone used some comet clutch spray, I don't see any of that here at the place I usually get clutches.
anderkart
Surprise Arizona USA
I use this brand:--> http://www.homedepot.com/buy/dial-4-oz-evaporative-cooler-zoom-spout-oil-5714.html of evaporative cooler oil on my clutches bushings or needle-bearings, you can buy it from most any hardware store. This bottle has an internal straw that pulls out several inches longer. This handy feature really helps to accurately apply the 2 or 3 drops of oil, I drip onto the outer-edge of my clutches drive gear, so I can spin the clutch drum and work the oil into the bushing/bearing.
I usually start out by spraying a little WD-40 around that area to simply clean the dirt/old chain lube off the clutch/engines output shaft and clutch retaining bolt.
Then I elevate the left side of my kart a little higher, so gravity will help flow the 3-drops of oil into the clutches bushing, (that's almost always located directly inside its drive gear). Then I spin the clutch drum to help work the oil in...
The reason for only using 2 or 3 drops, is; you just want enough to only lube the bushing, not enough excess oil where It'll wash past the bushing and contaminate the clutches internal shoe/drum area...
