oil catch can
pearl111
Baltimore, Maryland
Is it necessary to have a catch can on a Pre. 212 hemi with gov. removed and new high flow air filter and muffler and rejetted carb? I thought I read this is needed do to higher RPMS which causes higher oil pressure. I do have a small filter on a short hose from the valve cover hole where the hose use to go to the original air box. Thanks DIY.
karl
North east Ohio
A catch can catchs oil. If you run without you may have oil drip out the breather. No witchcraft involved. Its nice but not essential.
Bbqjoe
Banned
Location, Location
��The oil can....��
�� The oil catch can��
��The oil catch can because it mixes it with love and makes the world taste good!��
How much oil could an oil catch catch,
If an oil catch could catch oil?
anderkart
Surprise Arizona USA
Race karts use catch cans to help keep from oiling down the track, and spraying hot oil all over the other drivers/karts racing behind them.
pearl111
Baltimore, Maryland
I guess mini bikes could use the cans to keep the oil off tires, motor, frames, components ect.. I know that 2 stroke motors like to get oil over ever thing. Here's a thought I wonder if any one came up with a can for a 2 stroke, as messy as they are? Is it even possible to do so?
Bubba_Z
Bubba_Z
Western NC
2 stroke is not a vented system. I have seen a vent in the tranny (Case) but it is designed not to leak oil
Joe-405
Enjoying New Projects
U.S.A.
Unless it's high compression built engne then no you don't need it. Or 7000+rpms roughly.
