Jhoppe
I just picked up a yerf dog with the 6hp tecumseh powersport. I have had a kart with this engine before and i was not pleased with the performance. I want to do a mild build on it and was wondering if polishing the rod would be enough to remove the governor without grenading the internals. I know arc makes a billet rod, but I'm not looking to put much $$$ into it.
I will be retaining the stock cam, but I may improve the valve springs if I have a heavier set around. I am also going to jet the carb just a bit. Only a size or two up in my bit set. Will also do an improved intake and a header.
Is it worth the work for a few extra horses or should I just buy a predator? (Which will cut into funds for other improvements to the rest of the kart)
