Odyssey Snowmobile conversion - any advice
Kart wrencher
My son and I are stripping out a fan-cooled, electric start 540 engine from a Yamaha snowmobile. Our plan it to put it inside our FL250 Odyssey frame. So, here's the question:
The easiest option is to use the Odyssey clutch and chain drive mated to the snowmobile engine. then there are two trains of thought:
1. widen the Odyssey clutch to match the snowmobileto axle - cut on the clutch gearing
2. narrow the snowmobile engine clutch with a spacer to match the Odyssey clutch
Which makes the most sense?
We should be starting on this soon, so appreciate any advice.
Miike
bighead
Pacific Northwest USA
Miike
Here are some vids of the sled Ody I built a few years ago. Best to widen the Ody driven clutch to match sleds clutch. I also posted video I made on how to do that. Also a few other vids I made over the years that will help you out.
My best advice to you is get that engine as low as you can. And do not extend the frame.
Check out these vids. Then ask any questions you may have. I am the Odyssey freak. These vids should give you some ideas.
The clutch vid is a few years old now. In the vid I said a rode it a few times. Well it has lots of hours on it now and the clutching is perfect.
Can you post some pics? Would love to see what your working with. Also perhaps you have the comet clutches. Need any parts? I got small junk yard of Ody stuff.
http://www.youtube.com/watch?v=dhYpZcympiQ
http://www.youtube.com/watch?v=M6iiN3sL8xA
http://www.youtube.com/watch?v=j-RXoEyzYjI
http://www.youtube.com/watch?v=YX36AgTQoIE
Notice how it shifts in this vid. This is what your looking for.
http://www.youtube.com/watch?v=2NMOCQOjQcM
Kart wrencher
Big Head,
Thanks for the tips. Watched your videos many times. We are close to finishing putting a Yamaha 540 into the Ody. Here's where we are at.
1. We have placed the motor into the frame
2. welded motor brackets
3. added the throttle cable
4. added a rear suspension
and just have a few things left to do.
Right now, we are stuck at removing the Ody clutch hub to widen it to match the sled's belt width. how did you get he Ody clutch hub off? I saw that you broke one - we don't want to do that. :)
you mentioned having it machined by 3/16". What gets machined? I am ready to have this machined, so any advice you can give will be greatly appreciated.
I live near Portland and would like to drop by and talk for a few minutes, if you got some time this week-end. Will bring refreshments.
Mike and Alex
Big Head,
Mike and Alex
Looks like you are getting close to being done. Bighead sometimes takes a sabbatical from the forum, so you should maybe send him a PM to make sure that he gets your message.
Post some pics of your project please. We would like to see what it looks like
