Odd build needs torque
nyssa1966
Hello, iam new to the sight. I recently aquire a twister cart some one else started. It has a honda atc 200 mounted on it, that after I replaced the carb is now running. It is a clUtah less 4 speed, chain drive. Iam in need of some help in getting more torque for some hills on the farm we ride on. Would it help to reposition the motor farther back so it more over the top of the axle? What else can I do to still have power for flat runs but still torque for hills?
moving the engine around MIGHT help getting traction .. it'll surely not add even the tiniest amount of torque!
Also it most definitely is not clutchless.. so you might need to check the clutch discs for wear.
if you happen to know what atc200 engine is on your kart, it'd help to tell you how to do so.
Anyways, if it's more torque you're after, then the easiest thing to do
(again if it isn't an engine/clutch issue in the first place) is to increase the toothcount of your axle sprocket.
(if your's has fewer than 48 teeth you will most likely need to increase anyways)
nyssa1966
Hmmm, just counted, if I didn't miss any, lol, it's a 40. The engine, from what I can find out from engine number and what guy told me, was from a 3 wheeler
---------- Post added at 08:32 PM ---------- Previous post was at 08:30 PM ----------
Transfer doesn't seem to be slipping or not grabbing good, shifts good, a bit hard to shift with how set up, need bigger shifter set up to get better leverage, currently it's a very short shifter at seat
IIRC the hondas had a 41T final sprocket... thing is, those are much lighter than your average go kart, therefor you need to adjust for the additional weight
nyssa1966
My next question would relate to the rear tires and that sprocket. I have a larger diameters tire for the rear, so if I was changing up to like a 60 tooth sprocket, should I go larger with the bigger tires?
Getting larger rear tyres is like gearing higher. It would just cancel out the gains you get from a larger rear sprocket. If you want more torque without touching sprockets, you could get smaller rear tyres, but I don't think that is what you want though if you are going to use it offroad.
