Nuts
allanbranch
newbie gokart builder
I'm paranoid that the tires are going to fly off the go-kart. Do I need Tapered nuts or anything "special" as far as nuts on the wheels? How tight should the bolts be on the wheels?
porsche930dude
Upstate, NY
not very tight at all. the bearings arnt meant for side load. you should use a nylock nut if you can. if not you can drill the axle for a cotter pin so the nut cant back off
allanbranch
Nylock nuts, I should have known that.
I have a carter gokart, it's a 5/8 shaft on a 6" split rim. I use dust covers on the bearings and just a normal nut. But I'll switch to nylock.
Poboy kartman
Senior Moments Member
White Settlement Texas
Bad advice actually and what happens when you give a " shot in the dark " without enough information. ( Hence why we always want pictures. .....)
My Manco is designed to be torqued down....Inner and outer wheel bearings with an interior sleeve on the inner races of the bearings inside the wheel.....Sooooooooooo...all that gets tight....allowing no side to side movement- (or possible axle/spindle damage) due to a faulty bearing spinning metal on metal on either without warning. .... (and allowing the bearings to do what they were designed to do....)
Jest Sayin'........
rocketkart
florida
you always want a washer/spacer between (red) the inner sleeve/race and the nylock nut but! not exceeding the blue. this give it a small gap between the hole outer sleeve/race and the nylock nut. this will prevent the rims frome locking up when torqued down.
allanbranch
@rocketkart, so you can tighten down a bolt but only if the size doesn't exceed the center ring of the bearing and the washer doesn't go beyond the blue line! Thanks! Do you know the size of the washer? For this bearing? http://www.mfgsupply.com/az8206.html
I wish when I ordered bearings the site would say "here are washers and nuts for that bearing..." or "here's the ideal setup..."
porsche930dude
Upstate, NY
you dont need those dust shields for your bearings. those are for tapered roller bearings that are an open design. your bearings are sealed with the rubber. a washer is a good idea but alot of the time those nylock nuts already have a cutback on the back so you might not need it. also you cant tighten them down tight only snug beacause those bearings arnt designed for side loads. Unless you put a spacer between the bearings that supports the inner race. then you have sold metal on metal contact that you can tigten as tight as you want. but that spacer needs to be the perfect length inside the wheel
