thanks, definitely tell me whatever because i've never built anything like this. i want my bike to be street legal (that's why i got a 50cc engine) and will be getting a DOT full face helmet sometime. i also had to get an engine with a centrifugal clutch to be able to legalize the bike. i have a lot of wood working tools, a metal lathe that is not set up yet, 3 drill press, and a couple angle grinders. my school has a broken MIG and regular stick welders, i think i spoted a tube bender, and a small metal lathe that no one there rely knows how to use (exept me!
), a car lift, more angle grinders, ability to use pneumatic tools, and also the engineering teacher lets me use everything there. i have read a lot about welding but it kind of freaks me out (scared of light that could make me go blind)and that's why i've never learned. but now i will! i have a big shop that has a lot of tools and i can clean out my work spot to be able to bring in up to a car sized thing. i build alot of stuff out of wood so i'm good at that and am decent at machining unless i need to eat something which causes me to be unable to do math. i want some 26" fat near slick bike tires which i found on ebay awhile ago. i'm probably going to ditch the pedals so i can get a disk break in the back. i rely like the bike your working on! the fat back tire is awesome! i'm worried about the strength of my welds to so what i could do is build some simple clutch less weedy powered mini bike with breaks and a kill switch on the engine then drive it fast into a speed bump. or make a small cart, put a couple sinder blocks in it, use some of my r/c airplane stuff to control it and drive it into the speed bump. the second one is probably better.
sorry this was long and disorginized!
