noob
The RK
im new to the carting world i just got a frame with wheels and a steering system it just needs a engine. i was thinking the briggs 5hp but im unsure.. i couldnt find any pics of how to set up the clutch or were to get one and how they mount could some one shine some light on the drive system?
thanks
The RK
r_chez_08
Should be in the shop...
Cornwall, UK
welcome! a briggs 5hp would work, but if you dont already have it you could get a gx200 6.5hp clone engine. most people for a clutch use a centrifugal clutch ($30 - 100 ish). they come with different sized bores depending on what size shaft you have. most are 3/4". they work like this
for more money and to get the most from your engine you can buy a torque convertor ($200 ish).
neither need a cable for a foot pedal, and start working when your engine shaft hits a certain speed.
i am using a centrifugal clutch, which just mounts on to the shaft of the engine. here is a speed calculator to work out your approx top speed
The RK
ok thanks! so when you buy the clutch is the housing and the clutch actually one piece or do they separate? and wheres a good place to buy a motor and a clutch? do they already have sprockets built into them or is there another piece to buy?
