Noob with big tires needs gearing help
Speednoob
Hey all! Been lurking on this forum for a while but finally joined up. My buddy and I recently picked up a yard kart for 100 bucks and were trying to get it working. We've already cleaned it up real good and put a brand new predator on it however the gearing that came on it doesn't appear to be right. It came with a 10t clutch and a 53t sprocket in #40 chain and has 15in rear tires on it but it won't hardly take off with this ratio. Should I move the rear sprocket up to a 60t? Or should I put a 12 tooth clutch that I already have on it and change the rear sprocket to something else in a #35 chain? Thanks for any help and I look forward to being a part of this forum!
P.s. sorry for yet again another gear ratio post. I did search on my own for a long time but there's just so much good/bad info out there it's hard to figure it out. Thanks again.
Bbqjoe
Banned
Location, Location
I think you'd better stick with the 10 tooth clutch, and consider the 60 rear, maybe even go a little bit bigger.
The man who could get you dialed in is currently sitting in the corner, with a piece of bubble gum on his nose holding it against the wall, all while wearing a dunce cap.
Stay tuned...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
The 60 tooth will get you 6:1 gear ratio.
With 15" tires this should work.
It works great for me, with a stock Predator 6.5Hp 212cc engine on a simple light Yard Kart.
HP and weight may play a factor. You can look for a Larger 65-70 tooth axle sprocket.
The larger the Sprocket the more easy take off, and a little less Top Speed.
Show a Pic of the Kart, Possible you could just get 10 or 12" Tires too.
:iagree: A picture tells a thousand words; from just one pic, we can tell what itshould have...
It's possible the kart had a TC from the factory, which some deadhead PO removed...
Speednoob
Ok I'm going to try and take some pics when I get off work. It's a kenbar streaker d660 if that helps. I can't find a pic on the internet but it's pretty much just a standard single seater yard kart, no roll cage or anything.
Staff Murderator
A photo from the interwebz is no good. We need to see your exact setup because in all likelihood, it is not a 'factory' kart any longer. Besides, why gamble with guesses?
Speednoob
Ok guys sorry for the delay, I had to wait on my friend to send me a picture because I couldn't make it over there last night. This is what he sent me but it's not the best pic. If you need more I can go take some better ones tonight.
KartFab
Dallas, TX
53t? Maybe it's 54t. Either way, with 15" tires, that's not a bad ratio at all, unless you are trying to climb hills.
You may have a burned up clutch or a crappy engine that prevents you from taking off.
OR
You got a Manco go kart that has a 54t sprocket and original torque converter was replaced by a centrifugal clutch? That's not uncommon.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
[/URL][/IMG]
Ummmm Yes we will need more. FAIL
Staff Murderator
Guess he will always be a N00B. Not sure what speed has to do with it, except SLOW.
J/K... :D
Speednoob
well guys it wont let me post pics. idk why maybe I'm doing something wrong but ive tried everything.
Fixed it for you... obviously, you haven't tried everything...
The forum pic uploader doesn't recognise png files, you need to save them as jpg before uploading...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Cool now that Oz Fixed your Pic.
Ii can Confidently say that Going with a 60 tooth Axle gear and your 10t Clutch Should be no issue at all.
Unless you are a 250-300 Lb Linebacker.
Anyway 6:1 with 15" tires on a typical yard Kart like that works great for my Teenage Daughter and my Skinny 150Lb butt too
Speednoob
Thanks guys I'm terrible with computers lol but I really appreciate the help! Just got parts ordered
