Noob question on mounting engine
SabreT
Hi All,
I'm new on this forum and building go karts so I need all the help I can get.
I'm looking to convert a quad bike into a go kart. I'm going to use the suspension, wheels, engine and other bits from the quad. I'm looking to safe space and mount the quad engine vertical and not horizontal like it's mounted on the quad. Will this be safe for the engine?? Not sure please help!!
Will post pics as soon as I start with the fabrication.
SabreT
anderkart
Surprise Arizona USA
Your issues would be lubrication and the carbs float bowl. I'd imagine they designed your engine assuming the quad would spend quite a bit of time at extreme angles climbing/descending mountains, so I'm guessing you'd be fine with the lubrication aspect.
But you might consider modding the intake manifold so your carb ended up sitting level, that way your carb wouldnt ever be at too extreme of an angle when you climbed hills in your kart.
I dunno- we're talking 60* or more incline from normal, and constantly. Personally, I would not recommend it.
Aside from what Anderkart mentioned, there's also the tranny and clutch (again, lube) to consider.
SabreT
Thanks, I'll just stick to the way it were designed. the kart will be a bit longer but it that's no train smash.
Now to start fabrication, let the fun begins!!
SabreT
How important is having front and back suspension. I'm thinking of keeping the independent front and single back suspension setup from the quad with the 145/70-6 wheels.
Another option is to only go with the independent front and no back suspension. This will allow me to mount the engine above the back wheels, and run the chain vertically.
Which one is the better setup? help please.
fowler
Bullsbrook West Aus
rear suspension
it will be a bit longer (clearly) but will handle much better and will be way more comfortable there by more useful
