Noob Needing Part Advice
tossaroc
Does anyone know what the bolt part for this is and where I can purchase a replacement?
I think you are referring to the jackshaft, which in your case appears to be threaded - at least on the end.
The shaft that the driven pulley is on?
tossaroc
Jack shaft. That sounds right. Yeah. It’s a threaded bold that the sprocket is on. Do you happen to know where to find a replacement?
Thank you again for helping a noob!
tossaroc
The bolt, jack shaft broke.
I am working with a gear head, that’s what he calls himself, to upgrade the whole assembly as we speak. Apparently, this system is old and prone to failure. The upgrade is more reliable and doesn’t cost much.
Thank you all for your help and just plain awesomeness.
