Noob in FL
Highland doc
Central florida
Hi all, I'm a noob and just got my first kart for the kids. I don't know the year or maker, but it needs a little work. It is a 2 seater with a Tecumseh marked ohh50 that is missing the air cleaner, and fuel pours out if the carb through this intake. I'm thinking it will be easier to put a predator from HF on it than it would be to repair. It also needs a new brake band. Any advice is welcome.
Hursty
VOX NIHILI
Denver PA
:welcome2: Welcome to the forum. you will find lots of valuable/useful info here. post up some pics. some one here can tell you the make and model.
Please fill out your profile. it just makes things easier in the future. Thank You
:useless:
Poboy kartman
Senior Moments Member
White Settlement Texas
Well...you can take the complete OHH50-???? number and research that # and carburetor through Google......get a part# for a replacement carb....
Shop Amazon and get a replacement for about $20....
Do a little research on rebuilding those carbs....and tinker with the old one a bit....and possibly get it going for almost nothing.....
It's most likely either the idle pilot jet....or a stuck needle/seat/float.....the pilot jet may be as easy as seating it with a screwdriver....
I'm not a Tecumseh fan....but $20 for a good running engine and just a little effort..is worth a shot.....
Welcome to the forum! !!
Highland doc
Central florida
Im not real worried about the carb, I saw a bunch on ebay for next to nothing. Its the missing air cleaner that makes me lean toward just replacing the motor. I definitely need a new brake band, theres no brake material left on the old one. Its metal on metal!
Highland doc
Central florida
Thanks for the links chancer. I ordered a carb from amazon poboy. It was $18, so I didn't think I could go wrong. I'm from Ocala, about an hour north of Orlando
