noob help
millsaps
hey guys im new and have been dealing with manco magnum with subaru robin 6.5hp engine. i recently bought a new carb and i overflows draining into the intake which is what the last one did. i cleaned the tank and lines yesterday and flushed the system. maybe something already made its way into the new carb making it over flow?
help appreciated. dont know anything about carbs.
Take the bowl off the bottom of the carb (with fuel shut off or tank empty). See the floating doughnut? That's the float. Attached to it is the fuel inlet needle. Works like your toilet tank. When the level of fuel is too low, the float drops. That moves the fuel inlet needle off it's seat, letting more fuel into the bowl. When the level reaches a sufficient height, the float pushes the inlet needle back into it's seat, shutting off the fuel supply.
When fuel is being allowed in to the point where it pours all over the place, one of a few possible problems has occurred. There might be a particle stuck to the needle tip or the seat, which prevents the fuel supply from being shut off when needed. The needle or seat could be damaged. The float could have a defect that prevents it from floating, such as a crack that is letting fuel into the float itself, buggering up its buoyancy. The float could be sticking, or the needle detached.
Have a good look it it, and clean the needle and seat carefully. Remove the float, and shake it close to your ear to hear if there is fuel in it.
One trick I use to check float operation- remove carb from engine (intact and with bowl on) and attach several inches of clean hose to it. Blow into the hose while holding the carb upright, then flip it upside down. Repeat a few times. You should NOT be able to blow ait into it while it's upside down.
millsaps
my buddy's dad is gonna do the carb since he knows them well. now the next question. whats a good clutch for a predator 212 thats going to be un-governed and regeared.
I would suggest getting a Comet 30 series TC. What terrain are you going to be riding on though? You could get away with a centrifugal clutch if geared right.
You say it is going to be regeared. What is it going to be now? Post the sprocket tooth counts. That will give us a better understanding of what clutch you need
millsaps
its a street kart. doesnt want to spend the money on a tc.
millsaps
thanks. both karts are up and kicking ***. ill get some pics up for everyone to enjoy. going to do some speed runs here soon.
the manco magnum did 41mph yesterday with 2 people on it. the unknown predator karts did 34 in the rain 50-65% throttle.
