NOOB Engine Build with CVT and Reverse
Metoo0716
New_Cart_Guy
CT, USA
Hello everyone,
Please help. I have one of those 2 seat gocarts with shocks and stuff and a 150CC engine. It was great when my kids were little, but now it's just me and I would like to give this cart more power. I can design and weld, but I am having a problem understand what I need.
I would like to add a 16HP engine, and torque converter, but I do not want to lose reverse. What I have now is a dual chain. Are all these items, engine, toque converter, and final drive with reverse all separate items? I don't mind putting them together, but I just don't know what I need.
I also see online a complete gear box with reverse. Which is the better option?
I don't mind the work, but I want it to be the right options.
Thanks, in advance for your help and time.
Chris.:auto:
Metoo0716
New_Cart_Guy
CT, USA
Awesome!
Thank you so much. I will post pictures of the project as I go. I am hoping the engine mounting goes ok. I would like to retain some way to tighten the chain, so I have to figure that part out.
Metoo0716
New_Cart_Guy
CT, USA
Will I need a jack shaft for this application? Honestly, I am not even sure what that is. I imagine it all goes something like this. 1" engine output shaft goes to drive side of Torque Converter and then the belt to the driven side and then the forward/reverse gearbox and then chain to axle. Correct?
My current 150cc setup has two sprockets and two chains. Should I be doing the same?
Atlanta, GA
You are correct. Engine>Driver>Driven>FNR gearbox>Axle. At least that's how I have seen it done.
