Noisy Clutch? Flywheel?
xXLife_PrismXx
Ohio
When i start my engin up, it runs good at first but then when i start to ride it after a min or so it starts screechin and after a second or two it dies... i cant kill it in time cause it dont have a killswitch... wtf is going on?:confused:
euge
Are you talking about the eninge????
If you are, is it really loud sound???
If yes then i had they same problem with my briggs
I just sprayed some WD-40 into the ratchet, be sure to not oil the ball bearings in there, just the rachet i think there is a small hole to put some oil in there.
crazycart
RedNek Engineering
MINNESOTA
Yeha thats a common problem, ive also had clutches burn up and screech then it would stall out the engine. Id replace your clutch.
