qtband
So I figured I better double check this engine for my build since I last had it running a couple of years ago.
My problem is that I have no spark. I pulled the plugs and checked before I did anything and I had spark to one plug, not the other. That only lasted a few pulls. Now I have nothing.
Some info:
When I put a volt meter to the plug (C), and pull the start rope, I get voltage from the red and also the white wires. I assume that tells me that my points are operational.
I have a good connection between the the wires on plug (C) and the coil.
WHEN I PUT MY GROUND TESTER FROM THE RED WIRE AT (B) IT SHOWS A GROUND. IT ALSO DOES THIS AT THE WHITE WIRE (A). Does this mean my coils are bad?
If not, why don't I have spark?
Some info:
