No Spark Polaris Engine
qtband
St. Louis, MO
So I figured I better double check this engine for my build since I last had it running a couple of years ago.
My problem is that I have no spark. I pulled the plugs and checked before I did anything and I had spark to one plug, not the other. That only lasted a few pulls. Now I have nothing.
Some info:
When I put a volt meter to the plug (C), and pull the start rope, I get voltage from the red and also the white wires. I assume that tells me that my points are operational.
I have a good connection between the the wires on plug (C) and the coil.
WHEN I PUT MY GROUND TESTER FROM THE RED WIRE AT (B) IT SHOWS A GROUND. IT ALSO DOES THIS AT THE WHITE WIRE (A). Does this mean my coils are bad?
If not, why don't I have spark?
machinist@large
West Michigan, 49331
Some info:
I would start by double checking and cleaning/ replacing the points; when I got final ownership of my Farmall last year, I did all the usual to resuscitate it. Rebuilt carb, fresh fuel, and what I thought was a good cleaning of the points. Nada.
Because of time constraints, I called my neighbor who works on these things on a regular basis. What I thought were clean points, most definitely weren't. That's all it took. 15 minutes from his arrival till I had a runner. Which was good, because he had a welding job that I was needed for......
qtband
St. Louis, MO
I did that today. What I found out when I removed the flywheel is that my condensers were grounding out. I was told that these are notorious for bad condensers so....time for new ones and I'll see what happens.
Desertduler
Condensers do go to ground.
Scout
Nutjob
Indiana
Some info:
You have to understand how a points system works. There is power going through the points and into the coil. The coil is grounded. This creates a magnetic field in the primary winding. when the points open, the field collapses and the collapsing field creates a voltage in the secondary, when then lights off the spark. So, if you have continuity through the coils that is good. if you have constant power to the coils, that is bad. If you have no power to the coils, that is bad too. It is possible to have coils that test ok, but really aren't.
Also, it is hard to diagnose electrical stuff like "red wire" "white wire" without a schematic.
qtband
St. Louis, MO
That's why I posted a picture. You can see the red & white wires where they attach to the coils. I now have a picture of the internal wiring.
I have a schematic, but it's in the middle of a 400 page pdf file and I don't know how to extract one page for posting.
