SardisPaul
I thought I would be the good guy and buy my grandson a Kart for Christmas...as the saying goes, "no good deed goes unpunished".
The kart is an off road with a preditor 212cc 6.5 hp with a converter. The converter was a 30 series (asymetrical) and was running ok but did seem to struggle on inclines. After a few short rides ( maybe and hour in total) it started smoking the belt, and soon had no foreward momentum.
The converter was pitted and seemed to have seen better days so I ordered a new ( knock off) on to replace it. Install was straight forward but the new one has a belt that is 3/4" wide, the old one was running a 1/2 Comet belt 3200394 4213-139 (asymetrical). Everything I see says that a 30 series shpould be a 3/4". In any case I have zero poer to the wheels. Below are some specs & I apologize for the long post but without some guidance to get this fixed, this kart is going to go away and I'll have to find the kid a new 4 wheeler.
#40 chain
Driven = 10 teeth
Drive = 54 teeth
Rear tire = 22x11-8 22" tall from floor to top of tread
Front tire = 15-6-6 14" tall
Drive & driven pullys alighned with straight edge as were the chain sprockets.
Distance between converter pully centers is 6-11/16 " the rear (driven) has a 6" dia
The converter drive and driven pullys both open and close with the throttle ( seem to function normal ...sorry did not take a video of that)
The Kart rolls free and easy both directions when pushed.
The converter belt tension is about 1-1/4" halway between pullys
The chain tension is 1/4" to 1/2"
Any suggestions would be greatly appreciated
#40 chain
Driven = 10 teeth
Drive = 54 teeth
