No mixture adjuster screw ???
Jim-L-L
South Australia
Just realised the Carb. on my Briggs 3.5hp has no mixture screw ??? Any tips on adjusting the mixture on these ??
If you have a newer, EPA regulated carb with no mixture adjustments, you get to do it the hard way like the rest of us! ;)
You basically have the choice between purchasing replacement jets in alternate orifice sizes, or doing what I do (because I'm cheap). If your existing jet is to small (running lean) use a precision drill bit to open it up to the nearest larger size. If the orifice is too large, solder the jet closed and re-drill smaller. The precision drill set you want will be in the #61-#80 range, and you'll need a pin vise (tiny hand drill) to go with it.
Jim-L-L
South Australia
Thanks Doc, Thought that might be the case, borrowed a set of number drills from a guy at work today but the smallest is # 60 dang it, Ebay here I come $$$
