no idea if this is a good deal
Jcotz
...wasn't there
NY
Probably produces plenty of power. What are you going to put it on? Also, if it runs well and he can show you it I'd say it is a good buy.
exenos
Project Nut
You would need to get a larger radiator for it, the proper expansion pipe ( not just any pipe a proper kawasaki invader pipe) if its not the right pipe then the timing of the pressure waves will be off and reduce the performance. You will also need to get both the primary and secondary clutches for it an they probably will be hard to find. I would recommend buying a full sled, taking the parts you need and parting out the rest, you should be able to make up at least 50-60% of what you payed for it.
matman55
I dont have a camera!!
Mims FL
i think ill put it on a kart of some sort.i dont think ill make another m.a.b outta this engine.
