Next project
Joel
Mcalisterville,pa
Hi guys. I'm back again from a long break. I don't hav pics on this phone right now but I'll try to get some.
I just bought a dingo kart from my neighbor. Wonderful condition. It has a 5 hp Briggs on it and it is slow and doesn't hav much power and that is not my type of thing.
Where shud I start for more power and speed??
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Make it fit. lol
But seriously a dingo should have no problem fitting a 212. Kartfab has a GX390 on his.
Eric87
Yes the motor was moved up and back . To clear the seat and make room for a torque converter. There is no dingo without a torque converter.
hardcorewill
Sc
Motor mount
Motor mounted on 2inch square tubing for tc clearance.
Eric87
I see the reason for the motor lift . But why did you cut the frame? You could have just made the 2" tubes 11" long and moved the motor back that way. No frame mod needed . Unless you wanted to stretch the wheel base. Your end result does look good . Just not sure I would want to lose all that frame.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Go see his thread. that is an articulating Frame!
and the silver parts on the very back is a Cooler rack!
http://www.diygokarts.com/vb/showthread.php?t=34066
pRoFiT
Can't buy it?, build it!
California
Is he using car tires!! i got to go look at his thread now. thanks guys. I've got similar pred/tav on mine and i think i need to bring it up 2" as well from frame. hmm. good to see someone with it mounted that way.
Not so fast, there Buster!
I got a Dingo without a torque converter. :thumbsup:
Check it out.
https://www.youtube.com/watch?v=_5EK9EOulsY
On this test ride, the controller had some issues but, the kart moved right along.
It's only set up to run @ 36V right now, which with this motor, tops out @ 2,592 RPM's.
FYI: These motors produce 72 RPM's per volt of input & capable of running up to 72V.
So, if it's run @ 48V it produces 3,456 RPM's & so on.
@ 72V it would be cranking @ a whopping 5,184 RPM's
Instant torque & no (power robbing) converter required! :2guns:
