Newmar 125 w 2 speed shift question
v12mac
I just picked up a cart with the newmar db 125 motor. It has a 2 speed trans.. Can this be shifted on the fly or should the cart br stopped and idle?
machinist@large
West Michigan, 49331
Do you have photo's of this? Pictures make things much easier for all of us. Also would you please fill in your profile? It's helpful in case you are in a different part of the world, etc.....
jman231994
Australia
Id say it is a 2 speed auto clutch, let off the throttle to shift from 1 to 2. Stop to shift into reverse.
If it is a full auto then letting off the throttle would probably stop it changing gear. It should just upshift when the torque load on the gearbox is high enough, so it must have some throttle.
And yea, stop to go into reverse
Aint that one of those GY6 motors, or something like them.
Correct,
that's a GY6 (Lifan, Ducar or whatever some chinese company names it) or as you might wanna call it: a Honda clone (since the design is clearly taken from a Honda Monkey ;))
Anywho..
Any gy6 I know with reverse comes with auto clutch.
So as long as it moves you can shift between 1 and 2
(and -since I only know 3+1's- 3)
As soon as you try to shift into reverse it locks in neutral,
when you stop you have the choice to shift into reverse, when you move you cannot.
Just like rmm727 said.
jman231994
Australia
Some have indeed.. (most of the scooter variants have in fact)
But that's an option as any other gearbox.
straight five, four +rev, semi auto 2 gear and whatnot.
Ah righto, I've only seen the cvt ones. Though I don't think that's a gy6, pretty sure it's just a honda crf50/ct90 style engine clone. Which as far as I know is quite a different design to the gy6.
Off topic though sorry
