newby an hello to all
timbuc2
hello all,i am just trying to find out some info on honda engines and clutches for a two wheel dune-buggy type kart.and my main question is, does anyone know if they make a clutch or torque-converter type drive system for a 20hp 4-stroke honda engine with a beveled output shaft that came off of a big generator or welder.thank you in advance for any info on this matter.
Welcome to the forum. Unfortunately you are probably not going to find a clutch for that type of output shaft. You could machine it down to make it a straight shaft, or you can buy another one
timbuc2
ok landuse,that was kind of what i was expecting to hear,but i will let you know how things progress after i get the shaft turned,if that is ok with you.oh and have a nice day,ok.
firemanjim
Just kartin' around....
Houston Texas
I may have a cheaper/easier method for ya.... Why not buy a hubbed sprocket that fits the motor, that would drive a jackshaft of sorts with just a driven sprocket driving a TC set-up? Wouldn't that work? Maybe cheaper and easier than pulling out crank and having it machined down and put a keyway?
That would work, but where are you going to find a hubbed sprocket that will fit a tapered shaft. You will still have the same problem
