newbie
StormRider13
Springfield Mo
I just bought a go kart. Its a grasshopper go kart. Has a 5.0 power sport on it. I am currently upgrading to a torque coverter and hydraulic disc brakes.
Half-breeder
"Edit" button removed
Welcome to the forum... Please post pics/vid of any/ALL that you are speaking of. It 'helps' us to know what youre speaking of(plus pics/vids bring an audience... and if/when you got a question... an audience is ALWAYS handy!)
StormRider13
Springfield Mo
here are some pictures
StormRider13
Springfield Mo
So my plan is in order to finish installing the torque converter, I am looking at raising the engine 6 inches, and back about 2 inches. That should be enough room for the converter. I also replaced the 45tooth sprocket with a 60 tooth sprocket. I am looking at hydraulic disc brake. Due to the fact that I will be mounting the brake on the right rear of this kart. And the lines should be easier to route back to the left, to attach to my brake rod. Then I need to replace the 2 front tires due to the fact that air will not stay in them. Any suggestions or ideas to make this plan work is fine by me. thanks,
Welcome to the forum. Getting a 60T sprocket is going to give you some nice torque. Your top speed will be reduced though.
Do you know the reason why the front tyres are not holding air? Holes in the tyres? Have you got tubes?
Yeah, don't do that; raising the engine will raise the centre of gravity & moving it back will affect the handling because the weight will transfer behind the axle.
Move it across all you want but, that's about the only direction I recommend...
Fitting/replacing tubes will be a lot cheaper & easier...
StormRider13
Springfield Mo
Its kart is going to be road in grass mostly flat area. Maybe a 2 acres area. Some dirt road. Even moving the eengine back. It still does not put the engine over the axle. I have thought about the weight transfer but I am 200lbs and the seat is almost in the center. The 2 front tires are dry rotted and appears to have a pretty big crack in the center of tires. My main concern is hooking the brakes up. Hopefully it will work out.
