chrisinhou
- Messages
- 2
- Reaction score
- 0
Greetings,
I'm a total newbie so your mercy is truly appreciated. I'm a (relatively) handy guy .. more inclined to deal with electronics and woodworking before I mess with a vehicle. We found this abandoned cart we found behind a run in shed from the previous tenants of our house. I would truly appreciate any advice/help on what I need to buy and tips on rebuilding this thing to running status.
So here's what I know about the cart in it's glory days:
- It's a retail cart made by Carter; model is "Hot Bodies"
- It has had a recall because the rear axle is exposed
http://www.cpsc.gov/cpscpub/prerel/prhtml97/97061.html
.. I hope that doesn't mean it'll be difficult for me to find the right engine/config to drive the axle.
It's current status (besides rusting and gettin rained on):
- Engine, battery have been sitting there.. I assume it's toast. If not, I'm not gonna invest the time to try and fix the engine.
- Body seems fine and sound
- Tires are flat and the rubber is worn. I would not trust using them. would like knobby tread anyway. I'm hoping to salvage the rims though.
- Steering mechanism works and seems to be sound (although you'll notice in the pic that one of the rods is bent and on the other end it had rubbed the frame a little).
- Gas pedal/lever works; springs look good.
- Brake pedal/lever works; engages the brake "straps" on each wheel. Probably want to replace the straps since they are a bit rusted.
So, here's what I think I need (and yes, I'm cheap):
* the cheapo Harbor Freight engine ($99 coupon special); the 6.5hp greyhound (horizontal shaft/OHV)
-- related accessories to mount the engine and drive the rear axle
* set of tires that will fit the rims we have now
* replacement brake straps
* a comfy seat
Is this a sufficient shopping list to get this cart going? What else will I need? Again, thanks to anyone that even looked at this and is willing to offer any advice/feedback!
* a comfy seat
