newbie problems
bobc
I traded a garden tractor for a Kenbar s465 streaker cart last week. I thought it would be fun for my 11 yr old son but we are having some disappointing issues.
It has a 5HP B&S w/ a Max Torque centrifugal clutch w/10t drive gear and 54t sprocket on a live axle. 6" wheel radius.
The cart has very little appearance of wear but the clutch does not fully disengage. It wants to take off when you start it. The cart runs great on level ground once the clutch is locked up but it also stalls on sharp turns or slight hills. Starts well, (first or second pull on choke), idles well on run.
Tore the clutch down, cleaned it all up, shortened the spring about 5 turns and put it back together. You can start it now without it running away and it still locks up good at WOT. I plan on replacing the spring with heavier duty spring, guessing someone heated it up and its lost its temper, doesn't straighten out when you remove it.
The cart really runs too fast for our riding area which is mostly off road and hilly. Would like more power and less speed.
What can I do to fix the stalling issue (have done the common sense stuff, drained old gas, check plug etc.) and what is the best gear setup for our terrain? I don't see anything smaller than a 10t for the max torque. Should i do a jackshaft setup and if so what gears?
Trying to put a:auto: smile back on a disappointed 11 yr. olds face!
Tks
get a 60T rear sprocket, maybe even more (62-65 perhaps) and down goes the top speed and up the torque ;)
very hilly terrain, and a youngster driving it, maybe even 70T...
just see what speed you want.
http://www.diygokarts.com/speed-calculator.html
and, the stalling might be caused by that gear ratio,
if the engine cannot provide enough torque to get it moving it stalls of course,
with a higher gear ratio you'll have more torque and maybe it wont stall no more ;)
The thing with centrifugal clutches is they don't really like stop/start activity, it tends to shorten their life span. Constant heating & cooling caused by such use will cause the spring to soften &/or stretch. Another thought is that the idle may have been a bit high...
For that type of terrain & driving, you would be better suited to a torque converter.
Combined with the lower gearing that itsid suggested, I think you'll end up with one very happy 11yo boy...
With those Briggs fuel tanks, you have got to keep them relatively full otherwise the fuel pickup tubes can’t suck up the fuel when going into turns. The fuel gets pushed to the side off the tank and the pickup tube sucks air.
bobc
thanks guys for the tips. I think I'll try getting a 70T sprocket. I would do a torque converter but $ is a little short right now.:eek: I'm guessing I'll need a new chain or at least have to lengthen the one I have. I don't have that much slack in the setup. What is the dia. of the 70T sprocket? Will it work with the 6" radius tire setup?
I don't think the clutch was causing the stall out. It pulls fine under load on flat and straight just can't handle sharp turns or turn/hill combo. I think the tank pickup idea needs to be explored more. There is a big sponge like baffle in the tank. Never seen one of these before. Could it be obstructing? how do you get it out? I'll top off the tank and see what happens.
Assuming it's a #40 sprocket, it'll be a touch over 11"
6" tyres or 6" rims? Can you post some pics of your kart please?
Hold up, you didn't mention that before; what model 5hp B&S are you talking about? Again, can you post some pics?
6" radius would be a 12" diameter and a 11" sprocket, no.. that won't work, you'll run into a clearance issue.
I think you'll need a jackshaft to make that happen,
keeping your clutch and axle sprocket that'd be a
26T in and 20T out to get an overall gear ratio of 1:7.02
Does your engine have an oil sensor?
What happens if you detach it's cable?
