Jay7
Hey all i just bought this homemade kart and could really use some help setting it up. It's got a 6.5 hp 4-stroke engine, 5.3-6 tires, and what i think is a Hilliard extreme duty clutch with a 12 tooth sprocket that drives a 72 (apx) live axel. I have no experience with these things though and my big problem seems to be with the clutch. its kind of working but i think the chain is way to tight (it has practically no movement) but there seems to be no easy way to adjust it, the engine is mounted in single holes so i plan to redrill them for proper chain tension. the clutch has problems disengaging (probably not properly lubed either) and doesn't seem to completely engage, i was able to drive it a few hundred feet and the clutch was smoking. When i look at Hilliard's install instructions the clutch is actually flipped around with the sprocket on the inside but mine is on the outside...was it installed backwards?!?
