Newbie Clutch question
ralthoff
I am building my little brother his first go-kart and have a quick question. I acquired a B&S 3.5 hp engine for free, and it works great, but it does not have a keyway slot on the shaft. Do I need a keyway slot? I am looking at clutches and they talk about keyway types and I don't want to waste my money on something that will not work. Thanks in advance for the help.
Reece
EagleTalons
Master JB Welder
Forsyth, Montana
You need to take that engine to a machine shop and get a keyway cut into the shaft. The keyway "hooks" the clutch to the shaft so it will spin.
You could cut one yourself with a dremel or buy a crankshaft with a keyway.
Kaptain Krunch
Pro Junk Collector
vermont
I dont think i have ever seen an engine without some sort of keyway? is it tapered shaft? pictures...
ralthoff
ralthoff
sorry for the size, I didnt have time to change it. It is a 3/4 inch shaft, btw
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Typical usable kart engines have a 5/8" or 3/4" shaft with a 5/16 x24 internal thread along with a 3/16" keyway that runs the length of shaft.
Shaft does not appear to be long enough to support a centrifugal clutch. Need at least 2 1/4" in usable length.
Affair_driven
BULL DETECTOR
Wolf Point, Montana
Straight through clutch is what you will need. They are also known as 'bi-directional'.
Max-Torque makes good ones.
Try to test fit one before purchase.
The lack of a keyway complicates things.
ralthoff
I think my neighbors company has a mill that can cut a keyway, or is that a bad idea?
mike75925
thinker and tinkerer
Alto, tx
keyway is the place for a key, built in key means less parts because the key is made to the attachment(clutch, pump, whatever). either way the shaft should have a keyway.
