Newbie Chain Question
LEGION
I'm building a new cart, but don't know what chain to use. The clutch has 17 teeth and the axle sprocket has 60. Which one? Thanks in advance.
You need to know what pitch your chain is. Look at the links in the helpful links sticky in the FAQ section of the forum that deal with chain. Your gearing is going to be too high though with those sockets.
Nodroz
Belgium (Europe)
I suggest to use a 72 teeth sprocket because youre gearing will be a bit high. On the other hand you can decrease the teeth on your axle sprocket.
As landuse already said have a look at the stickies, to get the right pitch.
LEGION
If I do go the route of changing the sprocket on the axle, where do I get it? Reason I ask is because my rear axle is not a normal round shape. It's a hexagonal shape.
spyder1968
New Bedford, MA
sounds like a manco axle. does it have a hub on the axle that the sprocket bolts to? bmi has hex shaped wheel hubs, but i didn't see any sprocket hubs specifically for the hex axle. if worse came to worse you could prob have a machine shop turn one of their wheel hubs into a sprocket hub. the other option may be to switch the axle over to a regular (round) one. this would give you way more options for bearings,hubs etc. but unless you could find a donor kart, ( with an axle, bearings, wheels etc)it could get costly.
like Fabroman said though..............pics would help...a lot!
