new to me
BOBBYBJ
Quaker street NY
Well I got my kart it's not the best but when I'm done with it it will be a great kart and I will be building. 2 more
BOBBYBJ
Quaker street NY
Good morning I'm hoping this is ok to ask if not sorry but I need to know if a 70 amp welder is enough amps to weld on the kart I'm on a tight budget any help would be great?
Unknownkart
Davenport, iowa
Should be. But I would be careful if using an arc welder. Piping has a terrible tendency to blow out. And believe me, that will scare the **** out of you. Other than that, should be good. Just take your time. And don't be afraid to ask any questions about this topic. Everyone is usually friendly here. I have not been on here long. But the users of this site are generally happy to answer your questions.
best of luck to you! Hope to see it moving soon.and I hope this helps.
Do you already have that welder?
There are cheap wire fed options that people have been succesful with for around 100 bucks.
If chancer chimes in, he'll tell you how you can return it if you don't like it.:lolgoku:
Jrgunn5150
Rudderless
I started welding with a Harbor Freight 90 amp flux core welder. It did fine for a few year's, my brother actually still has it.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
"If" come on...
I learned how to "return it if you don't like it" (or you broke it) from You!
---------- Post added at 03:23 PM ---------- Previous post was at 03:22 PM ----------
Lots of guys here use that welder and really like it. :thumbsup:
Tell your Brother "GIVE IT BACK" MOM!!! He took my stuff!
Jrgunn5150
Rudderless
"If" come on...
I stepped up to the HF 180 lol. But it was great to learn with, and really affordable.
BOBBYBJ
Quaker street NY
hi guys I do not have the welder I was waiting for someone to answer me on the welding part any advice is great and I was going to buy one from harbor fright
Just began trying to weld. I'm using 90 amp flux core wire fed welder from HF. Throw the wire it comes with in the garbage, Get Lincoln wire.. I also upgraded to a much better grounding clamp. There are good video series about upgrading the welder to make it decent.
https://m.youtube.com/watch?v=_YHWb93-6PU
