New to Karting
Risk
Hello, I’m super green to Karting and would really appreciate some help. I’ve searched all over the internet for help but there’s very little information on beginner stuff. Firstly I’d like to start off by telling everyone I just picked up a 2019 Intrepid lo206. The motor has roughly 6 hours of use on it and is in really good condition. Now for my questions. I bought the Kart with a whole bunch of extras, now some of the extras I got was a bunch of led weights that are attached to the seat. Do I need to keep these on if so how many? I weigh roughly 165-172. Secondly, I checked the oil on the front oil fill on the Briggs motor and oil cane pouring out, is this normal, should I use the front oil fill to check the oil level or the rear oil fill? Another point, I took the cart down the road today and noticed after It was running there appeared to be smoke coming from the metal plate above the sprocket on the engine side (beside the seat). Now there was a chain protector that was zip tied to the metal plate and it definitely was melting, so that could be the case but I’m not sure if it was that or could be something else, like I said before the engine has 6 hours on it. Please if someone could point me in the right direction with what I should and shouldn’t do that would be great thanks.
1. The weights are a racing thing. If you are going to race the kart, you will have to learn about weights etc. Someone at the track will help you. If you bought this just for messing around in, then i would not even worry about weights.
2. Oil should not typically come out of the oil hole when you pull the dipstick out. It sounds like maybe it was over filled. You can use either the front or the back oil inspection hole. They are both at the same level.To put yourself and your mind at ease.....dran all the oil and then refill to the factory spec/recommended amount of oil. If it continues overflowing somehow, then we will have to look at other reasons why.
3. Sounds like something is getting really hot there, which could potentially indicate a problem. Post some pics of the area that is getting hot so that we know what you are talking about. Also, while you are about it, count the engine and axle sprocket teeth and post the count here. Lets see what your gear ratio is. And also what is your tyre height from the ground to the top
