new to forum
josh7owens
hey guys I'm new to the welding/metal work thing but not new to making stuff. I'm trying to decide on a welder. Its just going to be used for projects like building a go-cart. ect.
which one should I go with?
a) http://www.tractorsupply.com/weldin...-welders/hobart-handler-125-ez-welder-3806489
b)http://www.tractorsupply.com/weldin...mig-welders/hobart-handler-140-welder-3812040
c) http://www.lowes.com/pd_256722-1703...RL=/pl_Welding+_4294857445_4294937087_?rpp=60
also what kind of drill press should I get? I plan on getting a tube bender from hf, tube notcher from northern tools and a 8" grinding wheel. Anything else I need?
Also what size tubing to use? 1-1.25? thickness?
T-man
Missoula,MT
I would say 1" square tubing with .095 wall thickness. unless its for off roading then the 1.25 with .095 would work fine. just my 2 cents.
KieranM
Doin It!!
Kilkenny, Ireland
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I dont know how your budget is, im asuming its pretty good based on the welders your considering.
Sears has a pretty nice Delta 12in. Bench top drill press. It may not fit a tubing notcher though:
http://www.sears.com/shc/s/p_10153_...+&+Stationary+Power+Tools&sName=Drill+Presses
If you dont mind spending a chunk of change, Lowes has a 15" Porter-Cable floor drill press:
http://www.lowes.com/pd_78742-46069...57557_4294937087_?rpp=15$Ns=p_product_price|1
And Home Depot has a bunch of drill presses:
http://www.homedepot.com/Tools-Hard...10053&storeId=10051&catalogId=10053&langId=-1
If you want a bench drill press, make sure a tubing notcher will fit.
josh7owens
I'm not on a unlimited buget my no means but I rather buy once, than have to buy twice :)
Also for the guy the recommended the square tubing...
is that because its easier to work with or what? I would think square would be heavier and more exspensive then round? also most carts are round tubing so it goes with the norm.
thanks,
josh
T-man
Missoula,MT
josh, I mentioned square because that is what most of us diy'rs use in our first karts. some will build there first one that way and then do the next in round ( for the chalange )
devino246
Lynchburg, VA
square tubing is easier to fit-up and doesnt require a tubing notcher. The drawback is that square tubing cant easily be bent (that i know of).
Kaptain Krunch
Pro Junk Collector
vermont
You can bend square tubing. We have dies for it at school, but you obviously wont be able to bend tight radius' like round tubing.
