true true.. 4strokes have more torque (dulled down statement
but that's the thing, if you want low rpm torque,
then why do absolutely everything to reduce that in order to get higher rpms..
just to waste half of those to high engagment speed,
just so it moves at all?
We all know that if an engine has the same exact same horsepower at a certain rpm,
it also MUST have the exact same torque at that rpm.
And there's no handwaving around that.
And the engine that has MORE hp at that exact same rpms must also have more torque.
yes, two strokes bite way later (again washed out statement)
but if you raise your engagement speed to 4k+ anyways.. then the two stroke will likely be up to par out of the box.
plus it keeps on revving once the four strokes gave up.
So after all there's simply no sane reasoning to even try this past a certain point of money spent.
Don't get me wrong, having fun, throwing dirt does
NOT NEED sane reasoning whatsoever.. it's fun for a reason
I'm perfectly fine with that.
But it's terribly annoying to see -mostly- young guns spending
an unreasonable amount of money to get their lousy ootb
four strokes to rev higher and higher and higher,
just in order to waste most of those additional revolutions
to thermal losses
(clutch/belt wear.. stupid high engagement speeds in order to get the stupid setup to move at all and then gearing for 90mph when they only can achieve 55 anyways wasting another insane amount of rpms on the other end)
And then they get taught that this is how it has to be,
since racers do the exact same thing and in order to make it less terrible,
they 'need to' spend even more money.
When all that'd be needed really would be a better engine to start with.
that 10krpm 20 hp 190cc overhead cam four stroke for example
costs about 800 bucks new.
I'd bet it'd be hard to mod any industrial engine with the same amount of money and less than say 20hrs of labour (one busy wekend)
to get even close to that performance.
And if there's one k to spend, than an industrial plus mods
is not exactly the best engine to start with for many non racing folk,
yet they all get lured into that same madness since they think
"the racers should know what's best".
Again, I love the tilli block, and that head looks as georgeous as an engine part could.
I'd love to have one for myself (putting it on the shelf in the living room not having any real use for such
but if I wanted some more serious than say 10hp of power
for some fun project..
throwing money at an industrial engine would be the exact last thing I'd think about.
Now.. don't let me bring you down ..
if that's the kind of fun and entertainment you're after that is perfectly legit of course (as if I had a vote LOOOL
I'd just wanted to suggest,
that "more more more" might be easier and cheaper to find if
you think "other other other" too sometimes
